ONTAP EMS reference
wafl.attr events
wafl.attr EMS events occur when ONTAP encounters issues associated with large directory report operations.
wafl.attr.topK.clear.fail
Severity
ALERT
This message occurs when the large directory report fails to be cleared for a volume when this feature is turned off due to an internal error. Report on large directories might be unavailable or incorrect when it is turned on again.
Corrective Action
The system should attempt to resolve the problems by itself. If problems persist or further assistance is needed, contact NetApp technical support.
Syslog Message
Clearing the large directory report fails for volume "%s%s. Error: %s"
volname (STRING): Volume name.
vserveruuid (STRING): Universal Unique ID (UUID) of the volume's storage VM (SVM).
error (STRING): Error message.
wafl.attr.topK.init.fail
Severity
ALERT
This message occurs when the large directory report fails to be initialized for a volume due to an internal error. Report on large directories might be unavailable or incorrect.
Corrective Action
Syslog Message
Initializing the large directory report fails for volume "%s%s. Error: %s".
wafl.attr.topK.scan.fail
Severity
ALERT
This message occurs when the scanning of the analytics database for large directories data fails due to an internal error. Report on large directories may be unavailable or incorrect.
Corrective Action
Syslog Message
Scanning analytics database for large directory report fails for volume "%s%s. Error: %s".
