wafl.attr events
wafl.attr.topK.clear.fail
- Severity
ALERT
 - Description
This message occurs when the large directory report fails to be cleared for a volume when this feature was turned off due to an internal error. Report on large directories may be unavailable or incorrect when it is turned on again.
 - Corrective Action
The system should attempt to resolve the problems by itself. If problems persist or further assistance is needed, contact NetApp technical support.
 - Syslog Message
Clearing the large directory report failed for volume "%s:%s. Error: %s"
 - Parameters
vserveruuid (STRING): Universal Unique ID (UUID) of the volume's Vserver.
volname (STRING): Volume name.
error (STRING): Error message.
wafl.attr.topK.init.fail
- Severity
ALERT
 - Description
This message occurs when the large directory report fails to be initialized for a volume due to an internal error. Report on large directories may be unavailable or incorrect.
 - Corrective Action
 - Syslog Message
Initializing the large directory report failed for volume "%s:%s. Error: %s"
 - Parameters
wafl.attr.topK.scan.fail
- Severity
ALERT
 - Description
This message occurs when scanning analytics database for large directories data fails due to an internal error. Report on large directories may be unavailable or incorrect.
 - Corrective Action
 - Syslog Message
Scanning analytics database for large directory report failed for volume "%s:%s. Error: %s"
 - Parameters
