wafl.attr events
wafl.attr EMS events occur when ONTAP encounters issues associated with large directory report operations.
wafl.attr.topK.clear.fail
- Severity
ALERT
- Description
This message occurs when the large directory report fails to be cleared for a volume when this feature is turned off due to an internal error. Report on large directories might be unavailable or incorrect when it is turned on again.
- Corrective Action
The system should attempt to resolve the problems by itself. If problems persist or further assistance is needed, contact NetApp technical support.
- Syslog Message
Clearing the large directory report fails for volume "%s%s. Error: %s"
- Parameters
volname (STRING): Volume name.
vserveruuid (STRING): Universal Unique ID (UUID) of the volume's storage VM (SVM).
error (STRING): Error message.
wafl.attr.topK.init.fail
- Severity
ALERT
- Description
This message occurs when the large directory report fails to be initialized for a volume due to an internal error. Report on large directories might be unavailable or incorrect.
- Corrective Action
- Syslog Message
Initializing the large directory report fails for volume "%s%s. Error: %s".
- Parameters
wafl.attr.topK.scan.fail
- Severity
ALERT
- Description
This message occurs when the scanning of the analytics database for large directories data fails due to an internal error. Report on large directories may be unavailable or incorrect.
- Corrective Action
- Syslog Message
Scanning analytics database for large directory report fails for volume "%s%s. Error: %s".
- Parameters
