ONTAP EMS reference
cluster.epsilon events
cluster.epsilon EMS events occur when ONTAP encounters issues associated with epsilon assignment operations.
cluster.epsilon.assign.fail
Severity
ERROR
This message occurs when automatic assignment of epsilon to a node fails, alerting the customer that there is no epsilon on their system. Attempts to assign epsilon continue until automatic assignment succeeds or epsilon is assigned manually.
Corrective Action
Try to manually assign epsilon to a healthy node using the command 'cluster modify -node node-name -epsilon true'. Contact NetApp technical support if epsilon cannot be assigned.
Syslog Message
Epsilon could not be automatically assigned to node %s with error %s.
node (STRING): Name of the node that epsilon was being assigned to.
error (STRING): Error string detailing why epsilon assignment failed.
cluster.epsilon.assigned
Severity
INFORMATIONAL
This message occurs when epsilon is assigned to a node either manually by a user-initiated command or automatically by the system.
Corrective Action
(None).
Syslog Message
Epsilon was assigned to node %s by %s.
node (STRING): Name of the node epsilon was assigned to.
actor (STRING): Whether the change was made manually by a user command or automatically by the system.
cluster.epsilon.removed
Severity
INFORMATIONAL
This message occurs when epsilon is removed from a node either manually by a user-initiated command or automatically by the system.
Corrective Action
(None).
Syslog Message
Epsilon was removed from node %s by %s.
node (STRING): Name of the node that epsilon was removed from.
