cluster.epsilon events
cluster.epsilon.assign.fail
- Severity
ERROR
 - Description
This message occurs when automatic assignment of epsilon to a node fails, alerting the customer that there is no epsilon on their system. Attempts to assign epsilon continue until automatic assignment succeeds or epsilon is assigned manually.
 - Corrective Action
Try to manually assign epsilon to a healthy node using the command 'cluster modify -node node-name -epsilon true'. Contact NetApp technical support if epsilon cannot be assigned.
 - Syslog Message
Epsilon could not be automatically assigned to node %s with error %s.
 - Parameters
node (STRING): Name of the node that epsilon was being assigned to.
error (STRING): Error string detailing why epsilon assignment failed.
cluster.epsilon.assigned
- Severity
INFORMATIONAL
 - Description
This message occurs when epsilon is assigned to a node either manually by a user-initiated command or automatically by the system.
 - Corrective Action
(None).
 - Syslog Message
Epsilon was assigned to node %s by %s.
 - Parameters
node (STRING): Name of the node epsilon was assigned to.
actor (STRING): Whether the change was made manually by a user command or automatically by the system.
cluster.epsilon.removed
- Severity
INFORMATIONAL
 - Description
This message occurs when epsilon is removed from a node either manually by a user-initiated command or automatically by the system.
 - Corrective Action
(None).
 - Syslog Message
Epsilon was removed from node %s by %s.
 - Parameters
node (STRING): Name of the node that epsilon was removed from.
