ONTAP EMS reference
rlm.network events
rlm.network EMS events occur when the Remote LAN Module (RLM) detects a link error on the RLM network port.
Severity
ERROR
This message occurs when the Remote LAN Module (RLM) detects a link error on the RLM network port. This can happen if a network cable is not plugged into the RLM network port. It can also happen if the network that the RLM is connected to cannot run at 10/100 Mbps.
Corrective Action
  1. Check whether the network cable is correctly plugged into the RLM network port. 2. Check the link status LED on the RLM. 3. The RLM supports a 10/100 Mbps Ethernet network in autonegotiation mode. Verify that the network that the RLM is connected to supports autonegotiation to 10/100 Mbps or is running at one of those speeds; otherwise, RLM network connectivity won't work.
Syslog Message
Remote LAN Module (RLM) network port link down due to cable or network errors.
(None).
