rlm.network events
rlm.network EMS events occur when the Remote LAN Module (RLM) detects a link error on the RLM network port.
rlm.network.link.down
- Severity
ERROR
- Description
This message occurs when the Remote LAN Module (RLM) detects a link error on the RLM network port. This can happen if a network cable is not plugged into the RLM network port. It can also happen if the network that the RLM is connected to cannot run at 10/100 Mbps.
- Corrective Action
Check whether the network cable is correctly plugged into the RLM network port. 2. Check the link status LED on the RLM. 3. The RLM supports a 10/100 Mbps Ethernet network in autonegotiation mode. Verify that the network that the RLM is connected to supports autonegotiation to 10/100 Mbps or is running at one of those speeds; otherwise, RLM network connectivity won't work.
- Syslog Message
Remote LAN Module (RLM) network port link down due to cable or network errors.
- Parameters
(None).
