ONTAP EMS reference
esh.element events
esh.element EMS events occur when ONTAP encounters issues associated with embedded switched hub (ESH) module communication.
esh.element.fault
Severity
ERROR
This message occurs when the filer cannot communicate with the ESH module.
Corrective Action
Check the cabling to the disk shelf. Verify that the SCSI Enclosure Services (SES) disk drives (0-1) are properly inserted. Check the status LED on the disk shelf, making sure that the fault LEDs are not lit. Clear any fault condition, if possible. Refer to the quick reference card beneath the disk shelf for information about the meanings of the LEDs.
Syslog Message
State of ESH module %s is %s on channels %s disk shelf id %d
element (STRING): ESH module designator (A is the upper module, B is the lower module).
state (STRING): Current state of ESH Module.
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID (1-7) of the disk shelf reporting the error.
esh.element.xport.error
Severity
ERROR
This message occurs when there is a transport error.
Corrective Action
Syslog Message
ESH %s XPORT ERROR on channels %s disk shelf ID %d.
