ONTAP EMS reference
fci.link events
fci.link EMS events occur when ONTAP encounters issues associated with Fibre Channel adapter link failures.
Severity
ERROR
This message occurs when the Fibre Channel adapter detects a break in the link.
Corrective Action
If the adapter is in use, check the cabling.
Syslog Message
Link break detected on Fibre Channel adapter %s.
adapterName (STRING): Name of the associated Fibre Channel host bus adapter.
Severity
INFORMATIONAL
This message occurs when the Fibre Channel adapter detects a break in the link due to a shelf firmware update being performed.
Corrective Action
No corrective action is required. This is expected behavior when firmware is being downloaded to a shelf.
Syslog Message
Link break detected on Fibre Channel adapter %s while downloading shelf firmware.
Severity
NOTICE
This message occurs when the Fibre Channel adapter cannot recover the link and the link is going offline.
Corrective Action
(None).
Syslog Message
Could not recover link on Fibre Channel adapter %s after %d seconds. Taking the adapter offline.
downTime (INT): Amount of time that the link is down.
