ONTAP EMS reference
wafl.descend events
wafl.descend EMS events occur when there is an error during descendency checking.
wafl.descend.fail
Severity
ERROR
This message occurs when there is an error during descendency checking. This message can occur when accessing a directory in a snapshot that is being deleted.
Corrective Action
This condition might be transient; try the operation again. If the problem persists, contact NetApp technical support.
Syslog Message
Descendency check failure: {x%x %d %d %d %d} parent of {x%x %d %d %d %d}. Contact NetApp technical support.
pfh0 (INT): Parent file handle's flags.
pfh1 (INT): Parent file handle's snapid.
pfh2 (INT): Parent file handle's fileid.
pfh3 (INT): Parent file handle's generation.
pfh4 (INT): Parent file handle's FSID.
cfh0 (INT): Child file handle's flags.
cfh1 (INT): Child file handle's snapid.
cfh2 (INT): Child file handle's fileid.
cfh3 (INT): Child file handle's generation.
cfh4 (INT): Child file handle's FSID.
vendor (STRING): Vendor contact information.
