snaplock.ss events
snaplock.ss.lockBadVolume
- Severity
ALERT
- Description
This event is generated if an attempt is made to lock a snapshot on a SnapLock volume that has previously failed to find or load its SnapLock snapshot state.
- Corrective Action
Run wafliron on the volume.
- Syslog Message
A snapshot on SnapLock volume '%s%s' on the Vserver with ID '%s', could not be locked because the SnapLock snapshot state could not be found or loaded for the volume.
- Parameters
volume (STRING): The name of the SnapLock volume on which the snapshot could not be locked.
app (STRING): Application Name.
volident (STRING): Unique identifier of the volume when the volume name itself is insufficient.
snaplock.ss.state.badMagic
- Severity
ALERT
- Description
This event is generated if the SnapLock snapshot state on a SnapLock volume is corrupt with an invalid magic file identifier. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
Run wafliron on this volume.
- Syslog Message
The SnapLock snapshot state is corrupt with an invalid magic file identifier on SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state is corrupt with an invalid magic file identifier.
snaplock.ss.state.badSize
- Severity
ALERT
- Description
This event is generated if the SnapLock snapshot state on a SnapLock volume is corrupt with an incorrect size. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
The SnapLock snapshot state is corrupt with an incorrect size on SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state is corrupt with an incorrect size.
snaplock.ss.state.badState
- Severity
ERROR
- Description
This message occurs when SnapLock® Snapshot® copies on the volume are corrupted, which prevents updates on the lockvault from succeeding until this is corrected.
- Corrective Action
Run the "snapshot fix-snaplock-state" command on this volume.
- Syslog Message
The SnapLock snapshot state is corrupt on SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): Name of the SnapLock volume on which the SnapLock Snapshot state is corrupt.
snaplock.ss.state.badVersion
- Severity
ALERT
- Description
This event is generated if the SnapLock snapshot state on a SnapLock volume has an invalid version number. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
The SnapLock snapshot state has an invalid version number on SnapLock volume '%s%s' on the Vserver with ID '%s'. The bad version number found was %d and the expected version was %d.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state has an invalid version number.
bad_version (INT): The invalid version number of the SnapLock snapshot state.
expected_version (INT): The expected version number of the SnapLock snapshot state.
snaplock.ss.state.createFail
- Severity
ALERT
- Description
This event is generated if SnapLock is unable to create the state for the SnapLock snapshot state on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
Failed to create the SnapLock snapshot state on SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state could not be created.
snaplock.ss.state.dir.createFail
- Severity
ALERT
- Description
This event is generated if SnapLock is unable to create the SnapLock state directory for storage of SnapLock state on a SnapLock volume.
- Corrective Action
- Syslog Message
Failed to create the SnapLock state directory for storage of SnapLock state on SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock state directory could not be created.
snaplock.ss.state.loadFail
- Severity
ALERT
- Description
This event is generated if the SnapLock snapshot state on a SnapLock volume failed to load. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
The SnapLock snapshot state could not be loaded from SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume from which the SnapLock snapshot state could not be loaded.
snaplock.ss.state.notFound
- Severity
ALERT
- Description
This event is generated if the SnapLock snapshot state cannot be found on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
The SnapLock snapshot state could not be found on SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state could not be found.
snaplock.ss.state.upgradeFail
- Severity
ALERT
- Description
This event is generated if SnapLock is unable to upgrade the the SnapLock snapshot state on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
Failed to upgrade the SnapLock snapshot state to SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
volume (STRING): The name of the SnapLock volume on which the SnapLock snapshot state could not be written.
snaplock.ss.state.writeFail
- Severity
ALERT
- Description
This event is generated if SnapLock is unable to write the the SnapLock snapshot state on a SnapLock volume. This volume will not allow SnapLock locking or unlocking of any further snapshots until this erroneous volume state is corrected.
- Corrective Action
- Syslog Message
Failed to write the SnapLock snapshot state to SnapLock volume '%s%s' on the Vserver with ID '%s'.
- Parameters
