protocol.exportcheckfailed events
protocol.exportCheckFailed
- Severity
ERROR
 - Description
This message occurs when there is an export check failure due to, either export-policy configuration not allowing access, or a non-existing filesystem/junction access attempt.
 - Corrective Action
Check the export policy configuration or filesystem name depending on the reason due to which export access check failed.
 - Syslog Message
Export access check failed on Vserver %s for client %s, trying to access volume %s, having policy %s, via protocol %s. Reason: %s
 - Parameters
vserver (STRING): Name of the Vserver where the issue occurs.
clientIP (STRING): Client for which the export access check failure happened.
volumeName (STRING): Volume name for which export access check failed.
policyName (STRING): Name of the export policy from which export access check failed.
protocol (STRING): Access protocol used by client for filesystem access.
reason (STRING): Reason for which export access check failed.
