hypervisor.memory events
hypervisor.memory.size
- Severity
ALERT
- Description
This message occurs when the amount of memory installed on the hypervisor is not sufficient for ONTAP® Select support.
- Corrective Action
Add more memory to the ONTAP® Select hypervisor configuration.
- Syslog Message
Insufficient amount of memory on the hypervisor: %s. ONTAP® Select requires: %s of memory.
- Parameters
size (STRING): Size of memory active on the hypervisor.
required (STRING): Size of memory required on the hypervisor.
