ONTAP EMS reference
diskown.disknotsup events
diskown.disknotsup EMS events occur when newly inserted disks are only supported with software disk ownership enabled, but it is not enabled.
diskown.diskNotSup
Severity
INFORMATIONAL
This message occurs when newly inserted disks are only supported with software disk ownership enabled, but it is not enabled.
Corrective Action
Halt the system by using the "halt" command, and then turn on software disk ownership by using the "storage disk assign" command. After you assign the disks, the system can recognize them.
Syslog Message
Newly added disk %s (and others) is only supported with software disk ownership enabled.
disk (STRING): Name of the disk.
