diskown.disknotsup events
Creating your file...
Your file is ready
diskown.diskNotSup
- Severity
INFORMATIONAL
- Description
This message occurs when newly inserted disks are only supported with software disk ownership enabled, but it is not enabled.
- Corrective Action
Halt the system by using the "halt" command, and then turn on software disk ownership by using the "storage disk assign" command. After you assign the disks, the system can recognize them.
- Syslog Message
Newly added disk %s (and others) is only supported with software disk ownership enabled.
- Parameters
disk (STRING): Name of the disk.
