auto.policy events
Creating your file...
auto.policy.feature.enable
- Severity
NOTICE
- Description
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we start enabling the "auto" efficiency policy on the existing compatible volumes on All-Flash Optimized nodes in the background.
- Corrective Action
(None).
- Syslog Message
Volume efficiency features will be enabled on Volumes of All-Flash Optimized nodes in the Cluster.
- Parameters
(None).
auto.policy.feature.enable.done
- Severity
NOTICE
- Description
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we have completed enabling the "auto" efficiency policy on the existing compatible volumes.
- Corrective Action
(None).
- Syslog Message
Volume efficiency features were enabled on Volumes of All-Flash Optimized nodes in the Cluster.
- Parameters
(None).
auto.policy.feature.enable.fail
- Severity
INFORMATIONAL
- Description
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we fail to enable the "auto" efficiency policy on the existing compatible volume on All-Flash Optimized nodes.
- Corrective Action
Manually try enabling the inline Volume Efficiency features on the volume using the "volume efficiency modify" command.
- Syslog Message
Could not enable Volume Efficiency features for Volume %s of vserver %s.%s
- Parameters
volume (STRING): Volume name.
vserver (STRING): Vserver name.
reason (STRING): Reason for failure.
auto.policy.feature.enabled
- Severity
INFORMATIONAL
- Description
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we enable the "auto" efficiency policy on the existing compatible volume on All-Flash Optimized nodes.
- Corrective Action
(None).
- Syslog Message
Volume Efficiency features enabled on Volume %s of Vserver %s.
- Parameters
