ONTAP EMS reference
auto.policy events
auto.policy.feature.enable
Severity
NOTICE
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we start enabling the "auto" efficiency policy on the existing compatible volumes on All-Flash Optimized nodes in the background.
Corrective Action
(None).
Syslog Message
Volume efficiency features will be enabled on Volumes of All-Flash Optimized nodes in the Cluster.
(None).
auto.policy.feature.enable.done
Severity
NOTICE
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we have completed enabling the "auto" efficiency policy on the existing compatible volumes.
Corrective Action
(None).
Syslog Message
Volume efficiency features were enabled on Volumes of All-Flash Optimized nodes in the Cluster.
(None).
auto.policy.feature.enable.fail
Severity
INFORMATIONAL
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we fail to enable the "auto" efficiency policy on the existing compatible volume on All-Flash Optimized nodes.
Corrective Action
Manually try enabling the inline Volume Efficiency features on the volume using the "volume efficiency modify" command.
Syslog Message
Could not enable Volume Efficiency features for Volume %s of vserver %s.%s
volume (STRING): Volume name.
vserver (STRING): Vserver name.
reason (STRING): Reason for failure.
auto.policy.feature.enabled
Severity
INFORMATIONAL
This message occurs during upgrade to Data ONTAP® 9.3 or later, when we enable the "auto" efficiency policy on the existing compatible volume on All-Flash Optimized nodes.
Corrective Action
(None).
Syslog Message
Volume Efficiency features enabled on Volume %s of Vserver %s.
