ONTAP EMS reference
disk.spindleerror events
disk.spindleerror EMS events occur when ONTAP encounters issues associated with disk spindle motor problems.
disk.spindleError.detect
Severity
ERROR
This message occurs when a disk returns a spindle detect error. The disk will be recommended for failure.
Corrective Action
Disk firmware has detected spindle motor problems. The disk will be recommended for failure. If the disk is a member of a RAID volume,it will be failed by RAID when this error occurs on a RAID I/O and the raid group is not in degraded mode.
Syslog Message
Disk %s has reported a spindle detect error: (%x %x %x %x)
diskName (STRING): Name of the disk.
sense_key (INTHEX): Actual sense key
sense_code (INTHEX): Actual sense code.
qualifier (INTHEX): Actual sense code qualifier.
fru_failed (INTHEX): Actual FRU code.
disk.spindleError.notice
Severity
INFORMATIONAL
Corrective Action
Disk firmware has detected spindle motor problems. The option to recommend the drive for failure is not set, so the disk will not be automatically recommended for failure.
Syslog Message
(None).
sense_key (INT): Actual sense key.
sense_code (INT): Actual sense code.
qualifier (INT): Actual sense code qualifier.
fru_failed (INT): Actual FRU code.
