disk.spindleerror events
disk.spindleError.detect
- Severity
ERROR
- Description
This message occurs when a disk returns a spindle detect error. The disk will be recommended for failure.
- Corrective Action
Disk firmware has detected spindle motor problems. The disk will be recommended for failure. If the disk is a member of a RAID volume,it will be failed by RAID when this error occurs on a RAID I/O and the raid group is not in degraded mode.
- Syslog Message
Disk %s has reported a spindle detect error: (%x %x %x %x)
- Parameters
diskName (STRING): Name of the disk.
sense_key (INTHEX): Actual sense key
sense_code (INTHEX): Actual sense code.
qualifier (INTHEX): Actual sense code qualifier.
fru_failed (INTHEX): Actual FRU code.
disk.spindleError.notice
- Severity
INFORMATIONAL
- Description
- Corrective Action
Disk firmware has detected spindle motor problems. The option to recommend the drive for failure is not set, so the disk will not be automatically recommended for failure.
- Syslog Message
(None).
- Parameters
sense_key (INT): Actual sense key.
sense_code (INT): Actual sense code.
qualifier (INT): Actual sense code qualifier.
fru_failed (INT): Actual FRU code.
