The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fg.unconfig events
Creating your file...
Your file is ready
fg.unconfig.consts.exist
- Severity
ERROR
- Description
This message occurs when a FlexGroup detects constituents that are not properly configured and have not been removed after a sufficient timeout. This usually means that a failed attempt to expand the volume also failed to delete constituents.
- Corrective Action
Contact NetApp technical support for assistance.
- Syslog Message
FlexGroup %s has had constituents that are not properly configured for longer than %d seconds.
- Parameters
object_name (STRING): Name of the FlexGroup.
seconds (INT): Timeout period in seconds.
