fg.unconfig events
fg.unconfig.consts.exist
- Severity
ERROR
- Description
This message occurs when a FlexGroup detects constituents that are not properly configured and have not been removed after a sufficient timeout. This usually means that a failed attempt to expand the volume also failed to delete constituents.
- Corrective Action
Contact NetApp technical support for assistance.
- Syslog Message
FlexGroup %s has had constituents that are not properly configured for longer than %d seconds.
- Parameters
object_name (STRING): Name of the FlexGroup.
seconds (INT): Timeout period in seconds.
