dbs.upgrade events
dbs.upgrade
- Severity
ERROR
- Description
This message occurs when Distributed Block Store (DBS) detects a software upgrade is in progress longer than 24 hours.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
DBS has detected a software upgrade is in progress. Cluster fault type %s, fault ID %u, status %u. %s
- Parameters
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the upgrade.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
