ONTAP EMS reference
hwlicense.install events
hwlicense.install.fail.dl
Severity
ERROR
This message occurs when download of the hardware license fails.
Corrective Action
Check for command syntax errors, the correct file path, or network connection issues.
Syslog Message
Failed to download hardware license (%s).
package (STRING): Full path of the download package.
hwlicense.install.fail.json
Severity
ERROR
This message occurs when the downloaded license file is not in valid JSON format.
Corrective Action
Check the license file, making sure that it is in valid JSON format.
Syslog Message
Hardware license file is not in valid JSON format.
(None).
hwlicense.install.fail.prog
Severity
ERROR
This message occurs when the system cannot store the hardware license.
Corrective Action
Retry the download. If it still fails, contact NetApp technical support.
Syslog Message
Failed to store the hardware license.
(None).
hwlicense.install.fail.vrfy
Severity
EMERGENCY
This message occurs when the system doesn't have a valid hardware license.
Corrective Action
Contact NetApp technical support immediately.
Syslog Message
No valid hardware license is installed.
(None).
