ONTAP EMS reference
oss.config events
oss.config EMS events occur when a configuration file for the ONTAP® Status Service (OSS) server is modified from its original released version.
oss.config.file.modified
Severity
NOTICE
This message occurs when a configuration file for the the ONTAP® Status Service (OSS) server is modified from its original released version.
Corrective Action
If the modification was intentional, you can ignore this message. If the modification was not intentional, confirm that write access controls to the node's root volume are configured correctly.
Syslog Message
OSS has detected a modified configuration file. Process: %s, file: %s.
process (STRING): Name of the process that loaded the modified file.
filepath (STRING): The full file path for the modified file.
