scsitarget.fcp events
scsitarget.fcp EMS events occur when ONTAP encounters issues associated with small form-factor pluggable (SFP) modules in the Fibre Channel (FC) target adapter.
scsitarget.fcp.sfp.inserted
- Severity
INFORMATIONAL
- Description
This message occurs when a small form-factor pluggable (SFP) is inserted into the Fibre Channel (FC) target adapter.
- Corrective Action
You can obtain detailed SFP information by using the 'fcp adapter show' command.
- Syslog Message
An SFP was inserted into FC target adapter %s.
- Parameters
adapter (STRING): Target adapter name.
scsitarget.fcp.sfp.invalid
- Severity
ERROR
- Description
This message occurs when an invalid Small Form-factor Pluggable (SFP) is inserted into the adapter. For example, a 10-GB SFP was inserted into an 8-GB FC adapter.
- Corrective Action
Replace the SFP with a supported SFP.
- Syslog Message
The SFP in FC adapter %s is not valid. (%s)
- Parameters
reason (STRING): Reason for invalid SFP.
scsitarget.fcp.sfp.removed
- Severity
INFORMATIONAL
- Description
This message occurs when a Small Form-factor Pluggable (SFP) is removed from the Fibre Channel (FC) target adapter.
- Corrective Action
(None).
- Syslog Message
An SFP was removed from FC target adapter %s.
- Parameters
scsitarget.fcp.sfp.warning
- Severity
ERROR
- Description
This message occurs when a small form-factor pluggable (SFP) that is not supported for FCoE links is inserted into an adapter that is configured for FCoE. For example, a 1-GB SFP is inserted into a converged network adapter (CNA) port. Note that the underlying Ethernet link might still be supported with the original SFP.
- Corrective Action
Replace the SFP with an SFP that supports FCoE link speed.
- Syslog Message
The SFP in FC adapter %s does not support 10 Gbit/sec speed. FCoE is supported only at 10 Gbit/sec and so the FCoE link will not be online.
- Parameters
