ONTAP EMS reference
scsitarget.fcp events
scsitarget.fcp.sfp.inserted
Severity
INFORMATIONAL
This message occurs when a small form-factor pluggable (SFP) is inserted into the Fibre Channel (FC) target adapter.
Corrective Action
You can obtain detailed SFP information by using the 'fcp adapter show' command.
Syslog Message
An SFP was inserted into FC target adapter %s.
adapter (STRING): Target adapter name.
scsitarget.fcp.sfp.invalid
Severity
ERROR
This message occurs when an invalid Small Form-factor Pluggable (SFP) is inserted into the adapter. For example, a 10-GB SFP was inserted into an 8-GB FC adapter.
Corrective Action
Replace the SFP with a supported SFP.
Syslog Message
The SFP in FC adapter %s is not valid. (%s)
reason (STRING): Reason for invalid SFP.
scsitarget.fcp.sfp.removed
Severity
INFORMATIONAL
This message occurs when a Small Form-factor Pluggable (SFP) is removed from the Fibre Channel (FC) target adapter.
Corrective Action
(None).
Syslog Message
An SFP was removed from FC target adapter %s.
scsitarget.fcp.sfp.warning
Severity
ERROR
This message occurs when a small form-factor pluggable (SFP) that is not supported for FCoE links is inserted into an adapter that is configured for FCoE. For example, a 1-GB SFP is inserted into a converged network adapter (CNA) port. Note that the underlying Ethernet link might still be supported with the original SFP.
Corrective Action
Replace the SFP with an SFP that supports FCoE link speed.
Syslog Message
The SFP in FC adapter %s does not support 10 Gbit/sec speed. FCoE is supported only at 10 Gbit/sec and so the FCoE link will not be online.
