ONTAP EMS reference
kern.version events
kern.version EMS events occur when you reboot your system with a version of the Data ONTAP® kernel that is different from the one you ran previously.
kern.version.change
Severity
NOTICE
This message occurs when you reboot your system with a version of the Data ONTAP® kernel that is different from the one you ran previously.
Corrective Action
(None).
Syslog Message
Data ONTAP kernel version was changed from %s to %s.
oldver (STRING): Previous version of the Data ONTAP kernel.
newver (STRING): Current version of the Data ONTAP kernel.
