The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fal_nvme.init events
Creating your file...
Your file is ready
fal_nvme.init.failed
- Severity
ERROR
- Description
This message occurs when the Flash Adaptation Layer (FAL) NVMe subsystem fails to initialize.
- Corrective Action
Reboot the node. If the problem persists, contact technical support for assistance.
- Syslog Message
FAL NVMe subsystem initialization failed. Reason: %s.
- Parameters
reason (STRING): Reason for failure.
