ONTAP EMS reference
coredump.encryption events
coredump.encryption EMS events occur when ONTAP encounters issues associated with coredump encryption.
coredump.encryption.disabled
Severity
ERROR
This message occurs when encryption is configured on the controller, but the coredump subsystem cannot encrypt data. A system panic in this situation results in no core file being produced.
Corrective Action
(Call support).
Syslog Message
Coredump encryption cannot encrypt data. Core file will not be saved in this state.
(None).
coredump.encryption.restored
Severity
NOTICE
This message occurs when encryption is configured on the controller, the coredump subsystem experienced a transient problem encrypting data, but has since recovered and will be able to save encrypted core dump files in the event of a system panic.
Corrective Action
(None).
Syslog Message
Coredump encryption experienced a failure in the past but has recovered. Core files can now be saved.
(None).
