The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
cpeer.duplicate events
Creating your file...
Your file is ready
cpeer.duplicate.remote.addr
- Severity
ERROR
- Description
This message occurs when an IP address from a peer cluster is also in use by the local cluster in the same IPspace. This may prevent the cluster peering relationship from reaching an available state.
- Corrective Action
Replace the duplicate address on the local cluster with a different address.
- Syslog Message
Cannot use address %s from peer cluster %s because it is already in use on the local cluster.";
- Parameters
address (STRING): Duplicate address from the peer cluster.
peer (STRING): Name of the peer cluster.
