cpeer.duplicate events
Creating your file...
Your file is ready
cpeer.duplicate.remote.addr
- Severity
ERROR
- Description
This message occurs when an IP address from a peer cluster is also in use by the local cluster in the same IPspace. This may prevent the cluster peering relationship from reaching an available state.
- Corrective Action
Replace the duplicate address on the local cluster with a different address.
- Syslog Message
Cannot use address %s from peer cluster %s because it is already in use on the local cluster.";
- Parameters
address (STRING): Duplicate address from the peer cluster.
peer (STRING): Name of the peer cluster.
