ONTAP EMS reference
cpeer.duplicate events
cpeer.duplicate.remote.addr
Severity
ERROR
This message occurs when an IP address from a peer cluster is also in use by the local cluster in the same IPspace. This may prevent the cluster peering relationship from reaching an available state.
Corrective Action
Replace the duplicate address on the local cluster with a different address.
Syslog Message
Cannot use address %s from peer cluster %s because it is already in use on the local cluster.";
address (STRING): Duplicate address from the peer cluster.
peer (STRING): Name of the peer cluster.
