The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
appdm.l2 events
Creating your file...
Your file is ready
appdm.l2.notifyfailed
- Severity
ERROR
- Description
This message occurs when the system fails to notify the host of an event.
- Corrective Action
Verify the network connection between the host and the storage system to determine whether network communication is working correctly. If the condition persists, contact NetApp technical support.
- Syslog Message
On Vserver %s, application component %s, failed to notify the host of event: %s with error %s.
- Parameters
vsUuid (STRING): UUID of the Vserver that failed to notify the host.
appCompUuid (STRING): UUID of the application component.
notificationMsg (STRING): Description of the event.
errorString (STRING): Description of the failure.
