The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
raid.syncmirr events
Creating your file...
Your file is ready
raid.syncmirr.at.IOrecovery
- Severity
ERROR
- Description
This message occurs in a SyncMirror® configuration (with SyncMirror aggressive timeout capability), when RAID cannot service earlier timed-out I/O from the other plex.
- Corrective Action
To resolve this problem, complete the following steps: 1. Identify the problem aggregate, offline plex, and plex mirror status from the event logs. 2. Determine the reason for attempting to bring the plex offline, such as adapter, controller or multidisk failures. 3. Replace any faulty components that you discover. If you need assistance, contact NetApp technical support.
- Syslog Message
Expect longer I/O service time on plex %s due to error status %s.
- Parameters
plex (STRING): Name of the plex.
status (STRING): Status while the plex was brought offline.
