ONTAP EMS reference
mgmt.smbc events
mgmt.smbc.config.not.repl
Severity
NOTICE
This message occurs when the system fails to replicate the configuration of Report Target Group Port(RTPG) and Inter-Cluster(IC) LIF information.
Corrective Action
(None).
Syslog Message
Failure in configuration replication of RTPG, IC LIF information with relationship UUID "%s".
srcpath (STRING): Path name of the source group of the SnapMirror Business Continuity relationship.
dstpath (STRING): Path name of the destination group of the SnapMirror Business Continuity relationship.
relationship_id (STRING): Relationship UUID.
mgmt.smbc.proxy.create.fail
Severity
ERROR
This message occurs when there is a failure to create proxy I/O path channel between the SMBC peer clusters.
Corrective Action
Check the network connection between the source and destination volumes by using the "net interface show -role intercluster -status-admin up" command.
Syslog Message
Failure in proxy initiator %s and target %s creation.
proxy_initiator (STRING): Path name of the proxy initiator.
proxy_target (STRING): Path name of the proxy target.
error_msg (STRING): Description of the failure.
