ONTAP EMS reference
ctrl.link events
ctrl.link EMS events occur when ONTAP encounters issues associated with HA interconnect link quality.
Severity
ERROR
This message occurs when the software detects either symbol errors or out-of-sequence errors on HA interconnect links.
Corrective Action
If possible, replace the degraded interconnect cables and reenable automatic switchover by using the "options -option-name rdma.link_monitor -option-value on" command. If the problem persists after replacing both interconnect cables, replace the interconnect hardware on both nodes.
Syslog Message
Link errors detected on card in slot %d. Number of symbol errors (Port1:Port2): %d:%d; Number of OOS errors(RQ:SQ): %d:%d.
slot (INT): Slot number of the HA Interconnect device.
sym_err1 (INT): Symbol errors on the first port.
sym_err2 (INT): Symbol errors on the second port.
rq_oos (INT): Out-of-sequence errors on the receive queue.
sq_oos (INT): Out-of-sequence errors on the send queue.
Severity
INFORMATIONAL
This message occurs when the software initiates a switchover of the active interconnect link, which has been declared degraded.
Corrective Action
If possible, replace the degraded interconnect cable and reenable the automatic switchover by using the "options -option-name rdma.link_monitor -option-value on" command. If the problem persists after replacing both the interconnect cables, replace the interconnect hardware on both nodes.
Syslog Message
Link switchover initiated to switch active interconnect link %s.
degraded_port_name (STRING): Port name of the degraded link that is being switched from.
