ses.mismatch events
ses.mismatch.fw.version
- Severity
ERROR
- Description
This message occurs when the two disk shelf modules within the same disk shelf are running different versions of the firmware.
- Corrective Action
Download the latest disk shelf firmware to the disk shelf module that is not up-to-date.
- Syslog Message
The disk shelf modules on disk shelf %s.%d are running two different firmware versions. Disk shelf module A is running %s, and disk shelf module B is running %s.
- Parameters
channelName (STRING): Name of the adapter port or switch port.
shelfID (INT): ID of the disk shelf.
revision_str (STRING): Revision number for disk shelf module A, the top disk shelf module.
revision_str2 (STRING): Revision number for disk shelf module B, the bottom disk shelf module.
