The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
csm.ctfallbackswitchless events
Creating your file...
Your file is ready
csm.ctFallbackSwitchless
- Severity
NOTICE
- Description
This message occurs when the Cluster Session Manager (CSM) defaults to use CT (TCP transport) when creating LIF pairs because remote device ID information is not available on switchless clusters running CSM over remote direct memory access (RDMA).
- Corrective Action
(None).
- Syslog Message
Cluster Session Manager (CSM) could not determine the cluster ports that are directly connected between the switchless cluster nodes to create the RDMA connections for session "%s". CSM will use TCP connections as defaults.
- Parameters
uniquifier (STRING): Unique identifier for this session.
