csm.ctfallbackswitchless events
csm.ctfallbackswitchless EMS events occur when the Cluster Session Manager (CSM) defaults to use CT (TCP transport) when creating LIF pairs because remote device ID information is not available on switchless clusters running CSM over remote direct memory access (RDMA).
csm.ctFallbackSwitchless
- Severity
NOTICE
- Description
This message occurs when the Cluster Session Manager (CSM) defaults to use CT (TCP transport) when creating LIF pairs because remote device ID information is not available on switchless clusters running CSM over remote direct memory access (RDMA).
- Corrective Action
(None).
- Syslog Message
Cluster Session Manager (CSM) could not determine the cluster ports that are directly connected between the switchless cluster nodes to create the RDMA connections for session "%s". CSM will use TCP connections as defaults.
- Parameters
uniquifier (STRING): Unique identifier for this session.
