The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ha.takeoverimpversion events
Creating your file...
Your file is ready
ha.takeoverImpVersion
- Severity
ALERT
- Description
This message occurs when the partner node is down; however, due to a version mismatch, it is currently impossible to perform a takeover.
- Corrective Action
Upgrade the downrev node, so that both nodes are on the same release of Data ONTAP®. If a revert is being performed, downgrade the uprev node to the same release as the partner node.
- Syslog Message
Takeover of the partner node is impossible due to version mismatch.
- Parameters
(None).
