      ha.takeoverimpversion events
ha.takeoverImpVersion
- Severity
ALERT
 - Description
This message occurs when the partner node is down; however, due to a version mismatch, it is currently impossible to perform a takeover.
 - Corrective Action
Upgrade the downrev node, so that both nodes are on the same release of Data ONTAP®. If a revert is being performed, downgrade the uprev node to the same release as the partner node.
 - Syslog Message
Takeover of the partner node is impossible due to version mismatch.
 - Parameters
(None).
