esh.module events
Creating your file...
Your file is ready
esh.module.multiprob
- Severity
ERROR
- Description
This message occurs when the ESH might have failed because it is reporting multiple problems.
- Corrective Action
Replace the ESH module if the reported multiple problems are not valid.
- Syslog Message
channels %s disk shelf ID %d %s%s.
- Parameters
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID (1-7) of the disk shelf reporting the error.
element (STRING): ESH module designator (A is the upper module, B is the lower module).
reason (STRING): Reason the message is being sent.
