ONTAP EMS reference
esh.module events
esh.module EMS events occur when the ESH might have failed because it is reporting multiple problems.
esh.module.multiprob
Severity
ERROR
This message occurs when the ESH might have failed because it is reporting multiple problems.
Corrective Action
Replace the ESH module if the reported multiple problems are not valid.
Syslog Message
channels %s disk shelf ID %d %s%s.
channels (STRING): Channels that have the error if local, PARTNER for high-availability partner, UNUSED if unconnected.
shelfID (INT): Disk shelf ID (1-7) of the disk shelf reporting the error.
element (STRING): ESH module designator (A is the upper module, B is the lower module).
reason (STRING): Reason the message is being sent.
