The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ses.fw events
Creating your file...
Your file is ready
ses.fw.emptyFile
- Severity
ERROR
- Description
This message occurs when a firmware file is found to be empty during a disk shelf firmware update.
- Corrective Action
Obtain the correct firmware file from NetApp and place it in the /etc/shelf_fw directory. You can download the firmware file from the NetApp Support Site at http://support.netapp.com.
- Syslog Message
Shelf firmware file %s was empty.
- Parameters
fileName (STRING): Name of the empty file.
ses.fw.resourceNotAvailable
- Severity
ERROR
- Description
This message occurs when there is not enough contiguous memory available to download disk shelf firmware.
- Corrective Action
Reduce the amount of system activities before performing a manual disk shelf firmware update. If this does not resolve the issue, reboot the system.
- Syslog Message
Not enough memory available to download disk shelf firmware %s.
- Parameters
fileName (STRING): Name of the firmware file.
