ses.fw events
ses.fw.emptyFile
- Severity
ERROR
- Description
This message occurs when a firmware file is found to be empty during a disk shelf firmware update.
- Corrective Action
Obtain the correct firmware file from NetApp and place it in the /etc/shelf_fw directory. You can download the firmware file from the NetApp Support Site at http://support.netapp.com.
- Syslog Message
Shelf firmware file %s was empty.
- Parameters
fileName (STRING): Name of the empty file.
ses.fw.resourceNotAvailable
- Severity
ERROR
- Description
This message occurs when there is not enough contiguous memory available to download disk shelf firmware.
- Corrective Action
Reduce the amount of system activities before performing a manual disk shelf firmware update. If this does not resolve the issue, reboot the system.
- Syslog Message
Not enough memory available to download disk shelf firmware %s.
- Parameters
fileName (STRING): Name of the firmware file.
