ses.fw events
ses.fw.emptyFile
Severity
ERROR
This message occurs when a firmware file is found to be empty during a disk shelf firmware update.
Corrective Action
Obtain the correct firmware file from NetApp and place it in the /etc/shelf_fw directory. You can download the firmware file from the NetApp Support Site at http://support.netapp.com.
Syslog Message
Shelf firmware file %s was empty.
fileName (STRING): Name of the empty file.
ses.fw.resourceNotAvailable
Severity
ERROR
This message occurs when there is not enough contiguous memory available to download disk shelf firmware.
Corrective Action
Reduce the amount of system activities before performing a manual disk shelf firmware update. If this does not resolve the issue, reboot the system.
Syslog Message
Not enough memory available to download disk shelf firmware %s.
fileName (STRING): Name of the firmware file.
