kern.version events
kern.version EMS events occur when you reboot your system with a version of the Data ONTAP® kernel that is different from the one you ran previously.
kern.version.change
- Severity
NOTICE
- Description
This message occurs when you reboot your system with a version of the Data ONTAP® kernel that is different from the one you ran previously.
- Corrective Action
(None).
- Syslog Message
Data ONTAP kernel version was changed from %s to %s.
- Parameters
oldver (STRING): Previous version of the Data ONTAP kernel.
newver (STRING): Current version of the Data ONTAP kernel.
