netif.phyread events
netif.phyRead
- Severity
ERROR
- Description
This message occurs when there is a failure in reading the physical layer (PHY) of a network interface.
- Corrective Action
This might be caused by a software bug. If there are problems with the interface after seeing this message, contact NetApp technical support.
- Syslog Message
Failure in reading PHY for network interface %s.
- Parameters
ifName (STRING): Name of the network interface; for example, "e8a".
