ONTAP EMS reference
mcc.ic events
mcc.ic EMS events occur when the MetroCluster(tm) config module receives a node advertisement from any of its partners.
mcc.ic.process.node.adv
Severity
INFORMATIONAL
This message occurs when the MetroCluster(tm) config module receives a node advertisement from any of its partners.
Corrective Action
(None).
Syslog Message
(None).
sys_id (LONGINT): System id of the node sending the advertisements.
is_local_node_assigned (INT): Boolean specifying whether the local node has joined the cluster.
is_partner_assigned (INT): Boolean specifying whether the node sending advertisements has joined the cluster.
