dbs.node events
dbs.node EMS events occur when ONTAP encounters issues associated with Distributed Block Store (DBS) node maintenance mode or communication with the cluster master.
dbs.node.maint.mode.alert
- Severity
ALERT
- Description
This message occurs when Distributed Block Store (DBS) detects a node with a maintenance mode failure.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
DBS has detected a node with a maintenance mode failure. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
- Parameters
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID string of the associated node.
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the node in maintenance mode.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the CreateClusterFault API command and attached to the fault for testing purposes.
dbs.node.maint.mode.error
- Severity
ERROR
- Description
This message occurs when Distributed Block Store (DBS) detects a node is in maintenance mode.
- Corrective Action
Disable maintenance mode when maintenance is complete.
- Syslog Message
DBS has detected a node is in maintenance mode. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
- Parameters
dbs.node.offline
- Severity
ALERT
- Description
This message occurs when Distributed Block Store (DBS) detects the Cluster Master cannot communicate with the master service on a node.
- Corrective Action
Check for network connectivity issues and hardware errors.
- Syslog Message
DBS has detected the Cluster Master cannot communicate with the master service on a node. Cluster fault node %u, node UUID %s, type %s, fault ID %u, status %u. %s
- Parameters
cfDetails (STRING): Details of the node offline.
